Hi everyone. For adding a new light switch in living room, what’s the simplest way to run wiring through walls or ceilings? With the nearest power source across the room.
Adding a new light switch
Tags: None
Hi DK! Generally, you'd want to run the wire through the walls or ceiling, but this usually involves cutting into drywall, which can be messy and requires patching afterwards.
One approach is to go up into the attic (if you have one) and run the wire across the ceiling joists, then drop it down the wall where you want the new switch. If you're dealing with a finished basement or a multi-story home, you might need to consider running the wire along baseboards or crown molding, hiding it with wire covers that can be painted to match your walls.
Hi TinyTool! Are there any wireless solutions you’d recommend for adding a new light switch without having to run wires through walls? I’ve heard of smart switches, but I’m not sure how reliable they are.Comment
Smart switches and bulbs are a popular choice. You can replace your existing light switch with a smart switch, or use smart bulbs that can be controlled wirelessly. These often work through Wi-Fi or Bluetooth and can be controlled via smartphone apps or voice assistants. Another option is to use wireless switch kits. These typically come with a battery-powered switch that you can mount anywhere, and a receiver that plugs into your existing light fixture. They communicate via radio frequency, so they don't rely on your home's Wi-Fi. For a more traditional feel, there are also kinetic wireless switches. These generate their own power when pressed, so they don't need batteries or wiring. They pair with a receiver plugged into your light fixture.
The reliability of these solutions has improved significantly. However, it's worth noting that they may not be as foolproof as hardwired switches and could be affected by issues like Wi-Fi outages or dead batteries, depending on the system.
The breaker keeps tripping but only when I run the microwave AND the toaster at the same time, like clockwork every time. Is my house wiring dying? It's...
Channel: Electrical
