Hello Everyone! First post here, but long time lurker.
I am starting a major first floor renovation of my house. The house was built ~1910. I am about to replace all of the flooring on the main floor, and would first like to rip out all of the flooring, including the subfloor.
My question is this: Is it ok to remove the entire subfloor from the first level of my home before replacing any of it? My plan is to remove everything, down to the floor joists, find the "high spot" and then level all of the subfloor to the high spot.
The flooring that is in the house right now is not in too bad of shape, and is fairly level. I would build over it, but it already has a couple layers on it, and I would rather just put in the extra effort and "start from scratch" to make sure everything is flat and level.
Is there any problem I should be concerned about if I remove all of the subfloor before replacing any of it?
Thanks!
Thanks!
