Using OSB undera rug
  • radstorm61
    • Jan 2013
    • 6
    Hi all, it's been awhile since I been here. So hello I am planning to put down some area rugs on my sun porch area. They are 5x8 and I plan to use about 3 of them side by side. It is on a concrete slab so I want to put down some 7/17 OSb under the rug to keep it off the cold concrete in winter. Should I put down down some plastic sheeting between the concrete and the OSB as a moisture barrier of sort?
    Thanks
  • radstorm61
    • Jan 2013
    • 6
    Any suggestions?
      the plastic sheeting wouldn't hurt but since the slab isn't heated why go through the expense.
      • radstorm61
        • Jan 2013
        • 6
        Thank you for the reply HayZee.. I wasn't sure..so if it isn't a factor wont bother
