Bowed floor joist
  • Stevevan
    Bowed floor joist
    I have an older house that is 24 feet wide. The floor joist which are 12 feet have sagged in the center. The crawl space is tight but I would like to jack up the centers of the floor joist and support them with 4 x 4 or 6 x 6 post.
    I am considering using adjustable jacks or blocks on the supports.
    Would I need a footing under the jacks or blocks to maintain them under the house?
    Will this solve my problem?
    Outside and center footings are in good condition.
    Yes you would be best advised to add a concrete footer underneath any support system you use to level the floor, otherwise your floor will where you started from before you know it.
