I'm about two-thirds done sanding our 1971-vintage oak floor, or so I hope. Here's the question: Should I use sanding sealer before applying polyurethane or not?
I've got two gallons of Fabulon polyurethane and will probably get two or three more, enough to put down at least three coats on about 600 square feet of flooring. The old polyurethane has (at last!) been completely removed and now I'm using medium-grit (80) belts to remove any scalloping or rough places left by the 40- to 60-grit cut. What looked loathsome and scabby is starting to reveal a bit of glow, and all but a few bits of staining and surface damage are gone.
I run into a difference of opinion from books, online sources, and such on what to do after completing the medium cut.
Should I put down a coat of sanding sealer, let it dry, then sand it with fine paper? Or just proceed to a final cut with 120-grit? I have some 220-grit sanding screens intended for use with big stand-up floor buffers. From each I can cut two discs of suitable size for my small car-type buffer -- slow but it ought to do the job. But do I need this step at all?
What say ye, flooring mavens? Should I take back my gallon of sealer and use the money when I buy more polyurethane?
And while on the subject, I'd appreciate any opinions on Fabulon polyurethane. If it's overpriced junk I'd like to return it for credit before opening the first can. What I asked for was a heavy-duty polyurethane that would be highly resistant to moisture (water, cat accidents, et cetera), a real liquid-proof seal.
