Bathroom Floor repair
  • Bathroom Floor repair
    The family and I currently live in an older wood-framed home circa WWII era (it was once on-base officers housing that was moved into town after the war). Over the past few months, a problem has been brewing in the bathroom which all began with a small water leak in the wall behind the lavatory. The leak was repaired but the floor in the bathroom just behind the toilet had become water-logged (fiberboard subflooring from a previous shady contractor) and the flange on the toilet was cracked. I removed the toilet and repaired it as best I could but the problem continued and now the bathroom floor is soft and cracks have appeared in the vinyl sheet flooring.
    Heres the plan:
    After removing the toilet and vanity I will tear the floor down to the beams and see what condition everything is in. If there is water damage on the beams (i suspect one or more may be sagging slightly) I will sister on 2x6" beams using construction glue and 3-1/2" screws (with pilot holes and in a staggered pattern to prevent cracks). I intend to use a hydraulic car jack and some bricks/lengths of 2x4s to carefully bring the damaged beams back into level before reinforcing. I will probably replace all the cross-members under the toilet with CCA treated 2x6s as well.
    The flooring material I intend to use is two layers of 3/4" CCA treated plywood (construction glued to the beams and between the layers and nailed in place). The beams are 13" apart on center (odd I know) so the floor thickness should be sufficient. Once the demo and re-flooring is done, I will fill any anomalies in the flooring with wood-filler, sand smooth, clean thoroughly and put down vinyl tiles to complete the job.
    I have done some floor repair and framing in the past but this will be the most in-depth repair I have done. I guess I have a few of questions about the job..
    Are there any foreseeable problems with my plan?
    Are the vinyl adhesive backed-tiles going to adhere to the treated plywood?
    We have a 3-year old son. Using CCA (copper, cyanide, arsenic) treated plywood flooring, are there any health concerns for our son once it is covered with vinyl tiles?
    Sorry for the wall-o-text and thanks for any tips/advice you might have! P.S. The forum seems to ignore formatting on this post. Whats the deal?
    If man makes it, man can fix it!
    What "cross member" under the toilet are you referring to ? there should be the floor joists and thats about it.
    Your plan is good except if it were me I'd be bolting the sistered joists, tat is a much stronger way.
    Don't be cutting the CCA or CCQ or any treated lumber around your little fella, but once it is covered there should be no problems.
    The best way I'd see would be to use the 3/4" CCA/CCQ as the sub floor covering then use a standard grade floor covering of ply, this would be a much better base for stick on tiles.
      I am not much of a carpenter so I am sure my terminology is way off. Sorry for the confusion. By "cross members" I meant the short 2x6"s that connect the beams on either side of the 4" toilet line to form a box to support the toilet flange. The toilet is a full 2 inches lower than the rest of the room at this point so they must be in poor condition.
      Your right I think about bolting the sistered 2x6"s. Maybe some very large washers on either side to distribute the compression load on the wood. I'll pick up the hardware this evening.
      Also would you consider 3/4" treated ply to be an inferior sub-floor? Really what I am shooting for is a drastic over-engineering of floor strength. The wife is not a small woman and she has a tendency to dash into the bathroom and dive onto the toilet at the last second (which is why the flange was cracked and leaking).
      Is there perhaps a covering I could put over and glue to the CCA stuff to help with tile adhesion? I suppose I could leave it exposed for a while and let it dry out some before applying the tile. This kinda brings back the health concerns with our son though.
      Thanks for the tips by the way!
        No you can use the pressure treated ply for the first layer of sub floor then screw to that a layer 5/8" sheet of Advantech, just as strong and made for floor adhesion and for the application you need.
        If you still want to use the double layer of CCA/CCQ then add a 1/4" layer of flooring ply before you lay the peel and stick tiles.
        Don't forget though you should also use a "primer" before you lay the tiles, you can get it in any of the bog box stores in the flooring department.
        There is no real reason to replace the "cross members" around the toilet flange, the floor joists and the "double" layer of floor sheathing is way more than enough.
          Sub-floor.....
          Why is treated wood preferred for this application? I thought treating was to keep from being infested. Should be no infestation indoors. I would think untreated pine 2x's and sheet wood would be fine. I did similar in my place with a double layer of 3/4 ply on top of sistered joists. Sisters were glued and through bolted every staggered 18". Solid like a rock. If I do another, though, I'll lay the first layer diagonal.
            I opted for treated lumber for a couple of reasons:
            I live in a tropical and highly humid environment to begin with (south Texas only one block from the shore). In a bathroom environment, there is even more possibility of moisture exposure. It may be a little more expensive ($46 a sheet) but treated 3/4" provides near immunity from moisture and excellent longevity. It is also highly resistant to terminates which are also prevalent in this climate.
            Plywood, if I understand it correctly, is just a glued sandwich of alternating grain sheets. How would it help to lay it diagonally? It seems like this would require far more wood to get the project done.
            Would a sign-quality oil-based primer work on the floor-ply or is there a specific primer for this application?
            Floor height is going to be a concern if I add something on top of the 1-1/2" of flooring. I guess a small step up into the bathroom is a small price to pay for the peace of mind and the ability to park an M1-A1 Abrams Main Battle Tank next to the vanity.
            Is there another type of flooring that would be better suited to the treated plywood?
            I really appreciate all the advice! Having a couple (more experienced) heads to run the project by has really helped a lot.
              I don't think you'll go wrong with pushkins advice. He's up on top of it - captbob has been through the mill so to speak also but he's in michigan. good advice from great people! - hayzee
                The primer your going to need is a latex based primer specifically for treating of sub floor prior to laying vinyl of any description. It will be in the flooring department. Armstrong make one that I can think of and it should cost about $7 or so.
                  Well the demo is finished. It turned out to be a mix of old mid-1940s slats covered with plywood for about 8 inches on one side. The rest was plywood covered with ruined fiberboard. The slats looked to be fine and ended on a joist so I think I will leave them. They will be covered with another layer of high quality 3/4" anyway. The floor joists themselves turned out to be 2X10s and looked to be in wonderful shape even around the lavatory!
                  I ran into 2 problem areas with the flooring though. One side of the room has a fiberglass tub/shower combo. Both layers of (good) plywood run underneath the tub but there is some dry rot on the outer end where it meets the joist. I went ahead and cut everything back to 2 inches from the tub on the bottom layer of ply (sheathing?) and about 1 inch out on the top (subfloor). There are beams running perpendicular to the tub every 13 inches but I think I should hang some 2X6" joists parallel so the ends of that ply rest supported.
                  Also there is a water heater in the room enclosed in 1/2 plywood walls. The floor inside is in decent condition as there was no vinyl covering to hold in moisture. There is some overhang on the bottom side of it as well as a lack of support on the right that has me concerned so I am thinking of adding some joists here as well.
                  Here is a quick little diagram to show the condition of things:
                  Will this provide enough support for everything?
                  Also for the final floor prep, I am going to fill any voids/irregularities with "Well-Cote Water Putty" and glue+nail down a sheet of 1/4" floor ply on top of that. Would the peel-stick tiles adhere to a coat of spar varnish (more moisture resistance (and I have a gallon in the shed))?
                    Treated wood....
                    Ahh...Texas and termites. I'd use treated products also! (Our daughter and three G'kids are here for a month from San Antonio. They're talking like 70*'s is chilly weather!) Glad to hear the joists were in good enough shape. Sistering is such a pain!
                    • #11
                      There is no need to add the extra joists especially since you said previously that the existing ones are on 13" centers. Any additional joists would simply be a time and money eater.
                      Make sure your insulation under this floor has the faced (paper side) facing the room this is you insulation moisture barrier.
                      Make sure you fill all seams of the plywood sub floor with a putty.
                      You seem very worried about water problems on this floor, from my understanding your problem originated with a leaking toilet, unless the entire room (wall and all) is constructed from moisture resistant material then any water leaking will eventually find a problem. Water will soak from the treated material to a wall stud and then start it's problem area there. Your spending the time and effort to do the repair right and worry about extra joists and the like BUT at the same time your going to put down peel and stick tiles, in my humble opinion "this" is probably going to be your biggest problem area, moisture can get in between the joists of these tiles and start the process all over again.
                      If it were me I'd forgo the extra not needed floor joists and use a "single" piece of linoleum to cover the entire floor in one sheet. Any water dropped from the shower will then simply sit on top of it with no place to creep into. This to me would be a much better use of your money and time on this project.
                      • #12
                        The solid sheet of linoleum was one of the initial causes of the problem.
                        1. Small leak in northern wall (behind kitchen sink) soaks down onto subfloor from inside wall.
                        2. Moisture is trapped between sheathing and sheet linoleum.
                        3. Bathroom floor quickly forms soft-spots and no longer fully supports lavatory.
                        4. An unsupported toilet flange is not a load-bearing connection and cracks with normal usage causing secondary leak.
                        The initial leak was small. The fact that it managed to cause all this damage has me a little annoyed with sheet linoleum. Sure it looks nice and will protect the floor from small splashes from the tub (which has never been a problem for us anyway) but if, in a worst case sceneries like above, water does find its way in, will never allow that water to evaporate normally (I even ran a fan on the floor for days after the leak was repaired to no avail). I really want an escape route for moisture in that floor. Seeing moisture coming up between tiles will give me far more warning that there is a problem somewhere. My first indication when the floor failed this time was huge soft spots and a broken toilet flange.
                        I wouldn't say I am worried about moisture damage. It's more a case that I want it to fail next time in a manner that will give me more warning and opportunity to make minor repairs before the problem becomes serious like this.
                        • #13
                          What you have experienced is an unfortunate problem that occured in another room and no matter what the finished surface would have been, would have lead to the same problem.
                          Sheathing, no matter what sort ply, ACQ,ACC fiber board etc...etc... will absorb moisture, if the same problem happens again, the same area will get wet, granted it won't rot as your useing treated sheathing.
                          You said it ran down the wall cavity behind the kitchen sink, have you looked at the studs in this wall ? are you putting the new sub floor under this wall like the original would have been ?
                          • #14
                            Actually I thought that was kind of odd. The wall is resting directly on the floor joists there and the floor I replaced was simply butted up against it. The wall seemed in good condition so, aside from giving it a good cleaning and inspection, I figured it would be best to leave it alone. There is a lot of very strange previous construction and repair in this house..
                            As it stands this evening, I added the extra joists so all my sheets would end on support and put down both layers of 3/4" with 3-1/2" screws. The wood filler I used on all the little seams and screw holes is drying now. It feels solid as a rock! The wife and I talked about it and agreed with ya on the sheet linoleum. Easier and nicer looking as well as the added assurance of moisture protection. I think I am just going to give the floor a few days to dry out (our son is out of town at his grandmothers), prime and lay the linoleum right on top.
                            Any tips on assuring a really good seal with a lavatory wax ring? I've heard of using two rings stacked but it seems like this could obstruct the drain or cause a mess around the toilet. What do you think?
                            I think this project has come through 100% thanks in no small part to some good advice. It's much appreciated!
                            • #15
                              the toilet seal is really up to you. its not meant to "shore" up the commode to flange area it's just there to seal the flange - commode connection. you can get just the wax ring or a wax ring with a plastic reducing flange in it. the toilet is secured to the plastic -or- iron flange with the closet bolts. the flange should be fastened to the floor with screws so the toilet - outlet connection just doesn't "float" on the pipe.
