I am the second owner of a 30+ year old house that I am remodeling. I have lived in the house since 1993. I am putting laminate flooring in the first floor area (kitchen, dining room and entry hallway). In preparation for the flooring, I removed some carpeting in the DR and could see some water damage and some sagging of the floors along the three interior walls. I removed the floor/subfloor in the water damaged area and noticed that the 3 walls (loadbearing and supporting the 2nd floor and roof) were not centered over the floor beams. Two walls (parallel) were about 10 inches off the beam and riding over the floor joists. The walls increasingly sagged from the exterior wall side to where they connect to the third wall. From 0 to about one inch. It appears that each succeeding floor joist increasingly sags lower than the top of the beam. Joist hangers were not used. A two inch ledger board on the bottom of the beam supports the joists. The third wall connecting the two was centered between two joists and supported by the plywood only. To complicate matters more, much of the plumbing proceeds in the area of the third wall and beam. The concrete block support columns in the crawl space supporting the beams and joists were not located properly, thus the beams could go under the support walls.
I think that maybe the foundation and floor framing was completed and the wall design changed.
I plan to use screw type floor jacks and 4x6s under the walls to raise the floor enough to level it and be able to install the laminate. I will leave the jacks in place. The crawl space is tight but i have most of the floor in the DR up and have access to the beams/walls. No pictures available but I would appreciate any advice. I am an average DIY with sheds/decks/walls/windows etc on my resume. Am I missing something?
Second problem is that one of 3 2x10s from a separate floor beam that runs under a bath room has has been cut to allow drain pipe and water service line access for lavatory above. A water leak from the drain has weakened the cut 2x and caused it to sag dropping the floor an inch or so. I had a worker jack up the floor beam in two places with screw type jacks. this helped some; however, the floor is not level enough to install the laminate from the first problem. I plan to add another screw jack and see if I can level it some more. Again screw jacks will be left in place. Any comments?
Been thinking of just getting a contractor in and have them do it also. Wife is getting on me about not getting things done quick enough.
) as jacking the floor joists up and installing joist hangers and if needed the above mentioned extra support piers.
