Bathroom floor tile
  • DKAudio
    • Apr 2006
    • 454
    Bathroom floor tile
    I am going to tile my bathroom floor. I know that backerboard/Durarock should always be used but the area is really small (~8X4). Is it still needed or can I use a good thinset like FlexBond right on the plywood? I have never used backerboard before therefore, I have a couple questions...
    My house was built in 1954 and there is 1X6 or 1X8 (guessing) boards that run at ~45° on top of the joists. There is then plywood on top of that. Would the backerboard go on top and screw to the plywood? I am asking because once the tile is on there will be a fairly good height difference than the floor it meets to in the doorway.
    Thanks
  • The Builder
    • Aug 2009
    • 65
    Henry makes a wetbed type underlayment that you could mix and pour down. Read the manufacturers added additional recommendations. Certain brands recommend a mesh and so forth.
    • ceramictilepro
      • Oct 2009
      • 16
      Tile Installation over wood
      Schluter Ditra Mat is thinner than 1/4" backer board and imo performs way better and easier to install. Make sure your floor is sound without excessive movement like 1/8" in a 10' span. tip...put a cup of water in the middle of floor and jump up and down to see how much movement there is...it is expected to have some movement just not excessive. I have used ditra mat for years and will never go back to backer board.
      I am a licensed contractor that decided to make several video on how to install tile and one of them is a bathroom floor using ditra... i have some nice videos on how to install tile using ditra mat on my website
      ceramictilepro
      • sajesak
        • Jun 2023
        • 5
        Thanks
        Need some advice on repairing a soft spot in the rear bath of a 71 international. Spot is aproximately 6" x8" located in the center of the floor between the sink and the closets. Reading some of the other posts sounds a bit intimidating on the challenges of floor repairs. Would patching it be the best plan?
