Handling expansion gaps when installing large-format porcelain tiles.
  • Downaski
    • 409
    Hi there! Hoping everyone if fine. I need to know the best way to handle expansion gaps when installing large-format porcelain tiles over a heated subfloor. I’m aware that thermal expansion can be an issue, especially with radiant heating. Should movement joints be placed around the perimeter only, or would it be advisable to include them within the tiled area as well? Also, what’s the recommended width for expansion gaps in such installations to prevent cracking or lifting over time?
    A detailed answer would be helpful. Thanks in advance!​
  • Annahmed
    • 223
    Hello! Thanks for reaching out!
    Firstly, it's crucial to account for thermal expansion when installing tiles over a heated subfloor. The constant temperature changes can cause significant movement in the materials, which if not properly accommodated, can lead to cracking, lifting, or other damage to your tile work. For expansion gaps, you'll definitely want to include them around the perimeter of the room. This is standard practice for any tile installation, but it becomes even more critical with a heated subfloor. The general recommendation is to leave a gap of about 1/4 inch (6mm) around the edges of the room. This gap can be filled with a flexible sealant or covered with baseboards.
    However, given that you're dealing with large-format tiles and a heated subfloor, it's advisable to also include movement joints within the tiled area. The Tile Council of North America (TCNA) recommends including movement joints in the field of the tile at intervals of 20-25 feet in each direction for interior applications. For exterior applications or areas subject to direct sunlight or moisture, this interval should be decreased to 8-12 feet.
    For the width of these interior movement joints, a good rule of thumb is to make them at least as wide as the perimeter gaps, so about 1/4 inch (6mm). These joints should cut through all layers down to the substrate and be filled with a flexible sealant.
    When it comes to the layout of these joints, try to align them with architectural features where possible, such as changes in room shape, doorways, or the edges of large fixtures. This can help make them less noticeable in the overall design.
    It's also worth noting that the adhesive and grout you use play a crucial role in managing expansion. Use a high-quality, flexible adhesive designed for use with underfloor heating systems. For grout, consider using a flexible grout product, especially for the joints near the perimeter and any movement joints in the field of the tile.
    Lastly, be sure to follow the manufacturer's guidelines for your specific heated subfloor system. Some systems may have additional requirements or recommendations for tile installation.
    By carefully planning and implementing these expansion gaps and movement joints, you can help ensure that your large-format porcelain tile installation remains beautiful and functional for years to come, even with the added complexity of a heated subfloor. If you're not completely confident in handling this yourself, it might be worth consulting with or hiring a professional tile installer who has experience with heated subfloor systems.
    Hope this answers your question!
    • michaelthomsan
      • Feb 2025
      Great question! Including movement joints within the tiled area, not just the perimeter, helps prevent cracks. A 3-5mm gap is usually ideal for expansion.
