Hi everyone! How to stop bathroom tiles from being slippery? I am worried it could cause a fall.
Slippery tiles
Hi there!
To make your bathroom tiles less slippery and prevent falls, there are a few practical steps you can take.
One effective option is applying a clear, anti-slip coating made specifically for tile surfaces. This treatment provides extra grip without changing the appearance of your tiles, so it’s a great choice if you want a subtle solution.
Non-slip mats or adhesive strips can also work wonders, especially in areas like the shower or right by the sink, where water tends to make the floor slick.
Another long-term solution is to replace particularly slippery tiles with textured, anti-slip tiles in critical areas; these provide natural traction and are designed with safety in mind.
Keeping your tiles clean is equally important. Soap scum and residue from shampoos or cleaners can make tiles unexpectedly slippery, so using a cleaner that effectively cuts through these residues will help keep the floor safer. If you’re open to adding a bit of style, small rugs with rubber grips underneath can provide extra security around the sink or shower entrance. These simple steps can make a big difference in keeping your bathroom safe and slip-resistant.
Hope this helps!
Since this relates to rental property modifications and safety, it's best to focus on temporary, non-permanent solutions for rental properties to avoid any lease violations or damage.
For bathroom safety in rentals, I'd recommend considering these reversible options instead of permanent coatings:- Non-slip bath mats with strong suction cups
- Removable non-slip adhesive strips/treads (designed to be safely removed later)
- Machine washable microfiber bath rugs with non-slip backing
If you're specifically concerned about slipping, you should also discuss this with your landlord - they may be willing to implement a permanent solution themselves, as it's a safety improvement to their property. They might also have specific requirements or preferences about what can be applied to the tiles.
Hi Annahmed!
You need to be cautious about removable anti-slip coatings in rental properties. While some products claim to be removable, there are several important considerations:
Even "removable" coatings can potentially leave residue or slight discoloration, bond more strongly to tile than expected, especially over time, and require special solvents to remove, which could themselves damage the tile or grout. Your lease may consider such coatings a modification of the property.
What about removable anti-slip coatings? Are they easy to remove without leaving any marks?- The specific product used
- The surface it's applied to
- How long it's been in place
- Environmental conditions (heat, humidity, etc.)
I will back the suggestion of talking to your landlord for a permanent solution!
