I had a thermostat that wasn't working correctly so I changed it to a honeywell non programmable.
Prior to installing, the system was working but the fan would not automatically turn on when in heat mode.
The new thermostat is hooked up but there is a wire that I didn't know what to do with (not in the instructions for the thermostat.) The Blue wire coming out of the wall.
Also, nothing is working now. No blow from the air handler, and the compressor is not starting. Breakers are fine.
Is there a fuse on the air handler somewhere? I believe it's an Goodman AR 60. Please help, Im cold.
