kerosun monitor 30 heater
  • Bryand
    replied
    Monitor 30
    Originally posted by HayZee518 View Post
    I went to look at the MPI history and you were correct. MPI became a seperate entity in 1984.
    Most of the Monitor 30's have a sticker on them that says MPI if you remove the sticker, under it says kerosun. The first Monitor 30's and Monitor 20's said kerosun and did not have the MPI sticker. These are the heaters I cut my teeth on.
    replied
    heater
  • vangasman
    replied
    Actually it is Barrelgun that was looking for the manual, I was just trying to see if I could help if he had a problem. I have used mine for years so though I might be able to help if he had a problem. Monitor heaters this old were made by Kerosun before the split of companies. You can see the logo in the picture I posted, right next to the "Monitor 30".
    John
    replied
    heater
    well I'm not gonna start splitting straws on that, but Monitor Products International and Kerosun are two different companies.
    Kerosun uses a circular wick. No combustion blower, its almost like a kerosene lantern. It just sits there making heat.
    A Monitor has a combustion blower, circulating fan, heat exchanger, safety devices, fuel pump, igniter etc.
    Now, let's just get to the root of your problem.
  • vangasman
    replied
    It does say kerosun on it, they are a division of Toyotomi.
    replied
    heater
    then it IS a monitor heater. you threw me when you said a kerosun - 'cause I looked for a kerosun heater and I couldn't find one with that "30" model number. OK we're on the same page now :-)
  • vangasman
    replied
    This is a monitor 30.They were also called a KH80E. These were made before toyotomi and monitor split into two different company's. They also made a smaller one called a 20.
    replied
    heater
    can you put up a picture of the heater? I searched several screens for a kerosun heater and nothing shows up for a model 30 - kerosun makes heaters, so does toyotomi and dura heat.
  • vangasman
    replied
    I've worked on mine quite a bit over the years, whats not working?
  • barrelgun
    replied
    Originally posted by vangasman View Post
    No i don't, are you needing parts or having a problem? I know some places that still have some parts and I just bought a circuit board off a guy on E-bay that is parting one out. Let me know what you need.
    John
    I need to fine a manual for the monitor 30 heater I think this heater was made in the 80s
  • vangasman
    replied
    John
  • barrelgun
    replied
    Manual
    Doubt you'll find much since they haven't been produced since the 80s. I think I'm the last guy still using one, parts are hard to find. Let me know what you need, I may be able to steer you in the right direction.
    Do you have a manual for the monitor 30 heater
  • vangasman
    replied
  • barrelgun
    replied
    have you tried a dealer?
    Thanks I will try that
    replied
    kero sun
    Kerosene Heater Manuals
