It's at least 10 years old, Model LAT9416AAE, and just simply doesn't stop filling: water all over the floor. I've read there's a pressure tube, and I removed the plate behind the control console, and found the tube (black). But that's it. How do I get the tube unhooked so I can check it, or at least blow into it in hopes of clearing it?
Top Load Maytag Washer Overflows
I sooo glad I'm a plumber and not an appliance repairman...
Here is the parts diagram for your machine, washers really are horrible to work on...
And the parts you probably need...
5-Level Rotary Water Pressure Switch Part Number PS2019686 $52.66
Air Tube for Tub Fill Volume Part Number PS2019658 $23.19I stayed at a Holiday Inn Express last night.
Now I can Plumb!
