Drain Issues
  • welfordnremt
    • Mar 2011
    Drain Issues
    I have searched around the Internet and can not find a answer to why the toilet closest to the septic tank will not flush after a heavy rain, but the tubs and sinks in the house drain fine. The toilet furtherest from the septic tank will quit after a few days of heavy rain.
    Why does the tub still drain without issue?
    sounds like you don't have a stack vent. the sink and tub both have an overflow that admits air to assist with draining the waste line. if your toilet had a vent then draining the pot would't be a problem OR it has a vent but the line is clogged
    • Redwood
      • Feb 2009
      • 512
      I'd expect that you have a failing septic system and the pipe is filling with water.
      Now I can Plumb!
      • welfordnremt
        • Mar 2011
        I suspect the same thing, just trying to figure out why everything drains without issues, except for the toilet.
        • Redwood
          • Feb 2009
          • 512
          The vents on the toilets are lower and will flood first as are the drain lines....
          Now I can Plumb!
            Floods
            Could it be because the flush of the toilet introduces a volume of water higher than what a clog would allow to 'quickly' pass? Versus the draining of a tub or sink would allow a the draining of a lesser volume? (Not to mention the passing of any solids and such....through the partialy clogged drain, that is..)
            • Redwood
              • Feb 2009
              • 512
              Exactly! mrcaptainbob
              When the drain stops flowing things get ugly from the lowest point to the highest point....
              Now I can Plumb!
