Hi Everyone,
We just bought a new house that was completed in September. In it it has a propane furnace with forced air, and as well it has Radiant Floor heating that is heated from it's own small hot water tank which heats the basement floor and the the kitchen floor.
I've never had radiant floor heating, so this is all new to me... however I am pretty handy and know a little about a lot.
When the thermostat is set not to open up the circuit on the radiant floor heating I can feel the tank getting hot and the hot water line coming out of the tank is definitly hot. Also, there is power that is going right to the element itself (I tested it)
When I turn the thermostat on the water begins to flow throughout the system (I can see through the pex pipe in the manifold and I car hear it flowing and I can hear the little pump working). When the water flows the temperature on the hot water line gets cool and even after a whole day the floor isn't heating up... is this normal? How long does it take to warm this thing up???
Is there a different problem??
Ryan
Ryan
