If your flow is substantially less than that I'd match the pump closer to avoid cycling which is the enemy of motor life...
Motor starting uses a much higher amperage than run so that puts heat into the windings.
A motor that runs continuously will last forever while the one that starts every 2 minutes is doomed....
I have a customer with a home on an active spring that runs 1 BN-53 almost continuously with a 2nd one as a trim unit used during peak flows. They also have a Aquanot II as the back up with a standby generator. A power outage and generator failure during a peak flow is really the only time that they have to worry, which hasn't happened yet.
I've had very good luck with the Aquanot 12 volt pump knock on wood...
Sounds like debris is not a problem in your system.
Sorry about the confusing turn of the thread but when spammers arrive it sometimes gets hard to sort out the guilty parties...
