Have any of you used the PEX tubing instead of copper when plumbing your homes? Here in Chicago it is being used often as a cheaper alternative to copper. Just wanted to hear your experiences with it.
PEX tubing instead of copper???
I've just installed some PEX.
Not THAT cheap really because I can't keep costs down as I'm not a contractor
or buy it in bulk quantities.
The crimpers? Wow! are about $100 smackers.
The crimp rings go for about $10 per pack of 25pcs for 3/4" size around here.
I borrowed one from a very good friend instead. -
PEX is much cheaper than copper, a roll of PEX is around $50 (1/2" 100') same roll of copper around $200. Add on top of that the time and copper fittings to solder.
PEX advantage is that if it freezes it just swells and as it thaws it returns to it's original shape (almost anyway)
The Orange & Blue Big Box Stores will stock plumbing items regardless of whether they are code approved in an area or, not.
If there is a problem IE a leak, your homeowners insurance will note the unapproved illegally installed material and deny any claim for damages.
Now I can Plumb!
Now I can Plumb!
Pex is prone to fail due to freezing when used in shot pieces because they just can't expand enough before it hits a fitting. That said pex is all I use in Western Alaska because it will take so much abuse with freezing, but remember we arn't supose to freeze our pipes. Pex just helps when you do.Comment
Yes, that is correct. Short pieces with 2 - 7" between the metal connectors are prone to failure as an ice plug forms at the connectors then the freezing moves inward. The short piece does not have enough expansion to absorb the expansion of the water freezing.
There is also a type of PEX that has a layer of aluminum in it and this type does not fair well when frozen either.I stayed at a Holiday Inn Express last night.
Now I can Plumb!
I'm not so sure that I'd install an unapproved material in my home...
If there is a failure which happens and already has...(Kitec Class Action, Zurn Class Action, Rehau Class Action, Wirsbo/Uphonor Class Action, Dura-Pex Failures)
You'll be playing left out...
Then of course that other pesky matter of a home inspection when you go to sell your home...
Of course the illegal pipes will have to be replaced at your expense before the sale can go through...
Now I can Plumb!
