I recently (2 months) replaced both fill and flush valves in 2 toilets with Fluidmaster products. A week ago I noticed both toilets fill valves are turning on even though the water level in the tank is at the full mark. (Note: the water level at the full mark is below the overflow tube.) The fill valve runs for about 10 seconds before turning off. I did a test where I slghtly lifted the flapper allowing water to leak slowly into the bowl and found I had to allow the water level in the tank to drop at least 1.5" before the fill valve turned on. Therefore, this does not seem to be a problem with leaking around the flapper but a fill valve problem. Any ideas of additional adjustments I need to check/make? Thanks!
Fluidmaster value turns on/off, flush valve is new also.
What is your water pressure? How many PSI measured?I stayed at a Holiday Inn Express last night.
Now I can Plumb!
Did you know some Redwood Pipe is still in service today. -
Now I can Plumb!
Dye (blue) test on both toilets resulted in light blue water in bowls, so I'll be replacing the flappers next. Question about flapper design/fit, should part of flapper that protrudes into the water outlet be the same approximate diameter as the outlet? Currently, the diameter of both flappers protrusions is about half the diameter of the water outlet. Thanks!Comment
The plastic bushing opening is apprx 2 inches in diameter while the protrusion part of the flapper is apprx 1 inch dia. Are you saying the flapper protrusion diameter should be closer to 2 inches?Comment
How to Replace a Toilet Flapper
