Hi...please forgive me if I don't use the correct terms to describe this problem. I'm an amateur DIY'er. So, I have a second bathroom that I don't use much. My primary bathroom is being recaulked so I didn't want to use it until the caulk was dry so I went to the secondary bath. I go to run the hot water and the round knob is loose, but does turn on/off the water. I pop off the plastic round H and I see that there's a screw and it's loose. I grab the handy dandy phillips screw driver and tighten it. I try it and on the second or third turn, it's loose again. So I unscrew it all the way and discover that the screw has sheared off. The piece I have is roughly 3/4"-1" long. it's obviously broken off inside the part in the wall that turns on/off the water. The house is 35+ yrs old. The last time a plumber came to repair the drain, he broke it and had to replace the entire drain assembly with PVC! I think the plumbing is quite delicate (galvenized) and I'm scared to get it fixed. I am selling the house so I'm not interested in a full bathroom remodel! I think I could use loctite to hold the screw in tight for awhile. But I was really hoping there was a way to safely extract the other half of the screw and put a new one in.
Is there a safe way to extract this remaining screw piece without removing the part from the wall? Or should I go for loctite and hope for the best?
