Leaky Pipe - small fix I think - Newbie needs help
  • jg1234
    Hi Folks,
    In my basement I have a line that runs to an outside faucet. The valve that controls that line has a very small leak . Maybe it is the packing inside ? - The leak appears to be near the junction of the pipe to the valve.
    I was wondering if there was a solder or pipe dope that I could buy to stop that leak ??
    Any suggestions or recommendations would be greatly appreciated.
    Thanks - jg1234
  • kactuskid
    • Mar 2004
    • 801
    Try tightening up the packing nut with a wrench to see if the leak stops. If not you may need to replace the packing. Make sure you turn off the water supplying that faucet before disassembling.
    • jg1234
      Kactuskid,
      Thanks - I will give that a try and let you folks know.
      jg1234
