Garbage Disposal Clog
  • F8
    • Apr 2003
    My garbage disposal is clogged. This is the second time it's done it about 3 weeks, the first time drano worked. My fiance put a lot of cucumber pieces down there at once and it clogged. She then used drano to try to unclog it. Now the drano and water swirl when it's turned on, but it doesn't drain. Do I have to take it apart to unclog it?
  • BigBadUglyDude
    • Mar 2003
    • 5
    More than likely the clog is not in your disposal!! In the past my diposal has done the same and come to find out the clog is within the pipes around it. Some houses have an outside outlet that will allow a plumbing snake, older houses you may have to snake it from under the sink. My suggestion is stop the Drano and go with the snake.
    DJS
