I replaced the working parts of my toilet with a easy kit but I must have damaged the flex spiral metal tubing because it leaked and eventually broke when I was investigating. Now I need to replace this tubing. It's the tubing that runs from the water supply to the toilet.
What scares me is that it seems to be on the far side of the compression valve and it appears to be molded to the valve. I'm not sure if I can just use a wrench to detach the now broken hose and I'm really afraid of replacing the compression valve.
I can easily go buy some new tubing but what I'd really like to see is some pictures on how this is done. I see plenty on replacing the toilet and it's parts, but haven't found any on how to replace this tubing. Any ideas?
Edit: I took another look and I don't see how I can replace the flex metal tube. It appears to be one piece attached to the valve. There is no nut where the tube meets the valve, only smooth round metal.
