I need advise on how to attach a new toilet flange to an existing drain pipe made of lead. The lead drain pipe is soft enough that I was able to reshape the lip to the shape of the new toilet flange (ie: make it round again). But now I would like to learn how to attach a new flange to the drain.
Note: The house is a one story slab on grade, so the lead drain pipe goes thru the slab to the main drain line under the slab.
I have purchased a Brass Toilet Flange, assuming that is the best type to match up with lead.
This whole project started when I removed a toilet in my house to look for a water leak, only to find half of a toilet flange and it wasn't even attached to the drain pipe.
Can I do this project myself without damaging the lead drain pipe or should I call in an experienced plumber.
Thanks in advance for your help and advise.
Saturday Plumber
Saturday Plumber
