Ok, purchased home about six months ago. This is a shower only w/ a plastic (i assume plastic) pre-fab base and tile walls. The first leak was a drain issue, I replaced the rubber gasket (florestone), sealed it good...problem solved. I also put in a brand new door, sealed it up tight. Now, about a month or two later...carpet in closet (next to shower) was wet...pulled up carpet, shower had somehow leaked and the water headed toward the closet. Don't see any obvious cracks in the shower base. I pulled away some drywall in the closet to check out the back of the shower...pipes are not leaking, on/off control is not leaking, shower head is not leaking. The side of the base toward the closet is not leaking. Where I do see water is underneath the FRONT part of the base. By front, I mean the portion of the base that the door "sits" on..the part you have to step over to get into the shower. This front part, when you look back behind the drwall, has an upside down "U" shape. The water is originating under the front part of this "U". That is the weird part...that is where the water STARTS...it does not come from under the main part of the base. So I sealed the hell out of any other place I could imagine water was getting in...to no avail. Also, when I take a shower most times, doesn't seem to leak...but then when my wife does, the leak starts..usually right when she is done....don't know if this is a coincidence, or if the water just takes time to do what it is doing..or if we stand in diff spots and are making whatever crack may be there bigger...just don't know...I am running out of ideas and I am about to pull the sucker out (the base)....any ideas???????? If I do have to pull out the base, how hard of a project is this? Would I have to bust out the tile walls too? Here is a link for the model I believe I have:
Thanks!
Thanks!
