Pipes squealing
  • drhowarddrfine
    • Aug 2006
    • 9
    Pipes squealing
    Last week, I heard a squeal coming from the pipe leading into the house over to the hot water heater, but not the heater itself. I'm not sure of the exact point. The squeal starts whenever any water in the house is turned on and stops immediately when turned off. This continued while I was out of town.
    When I came back five days later, the squeal quieted, then went away. About two days later, it seems that any water faucet that is turned on starts with a slight 'rush' then returns to normal.
    What could this be?
    could have been a lime deposit in the pipe much like plaque in your arteries and narrowed down the interior opening. water can have pressure and velocity at the same time. pressure is any amount greater than one atmosphere. velocity is the speed at which a liquid travels. in the case of a narrowed pipe, pressure increases while velocity decreases.
