Sump Pump Check Valve Vibrates
  • morey1
    • Mar 2007
    Hello, quick question for the experts out there. I live in the
    midwest and have a sump pump in the basement. PVC from sump pump runs up the basement wall and across a 10 foot ceiling section and connects directly to something city-related underground (I think). All homes in my subdivision appear to be hooked up underground in this fashion.
    Our sump had been making a BANGING noise at the end of each cycle.
    Reading up about that, I determined it must be a bad check valve.
    Replaced that myself. Still a lot of vibration. Had a plumber come
    out...he recommended a new sump pump as our home is 12-years old.
    Plumber installed that, and told me to secure the ceiling PVC better
    to remove vibration. Winter came and I forgot about it. ;(
    Now that we've had some thaws, vibration came back worse than ever. I
    got some hangers and secured the PVC as solid as possible. Now, the
    vibration is localized to the check valve, and it lasts like 30-45
    seconds after the pump cycles. No banging, just loud vibration.
    I had saved the original check valve, which the plumber had said was
    still good. I put that back on, and all was quiet, until I noticed it
    was leaking around the upper rubber flanges. I tightened it down and
    now it's the same...massive vibration localized to the check valve
    after a cycle, lasting around 30-45 seconds.
    Any ideas what's happening? Thanks!!
