Reparing Hole in Garbage Disposal
  • Foley
    • Nov 2008
    Hello! I recently discovered a small (say about the size of the tip of a pen) hole in the side of my disposal. Of course, water is leaking out every time that side of the sink is used. Until we can get a new disposal, is there anything I can put on there for the time being? Maybe some plumber's putty or waterproof joint tape?
    Thanks in advance!
    You might be able to use some liquid weld, basically it's a two part epoxy that you mix together and then apply over the hole, it can be used in engine blocks to repair stripped threads and then re tapped, so I cannot see why you could use it as a temporary fix on the disposal.
    It's available at most big box stores and auto shops , comes under different names like Jen Weld, Epoxy Weld...etc.
    • Foley
      • Nov 2008
      Thanks, Pushkins! I'll give it a shot.
      • armataz
        • Dec 2003
        • 47
        marine weld is another option, either way it must be applied to a clean dry surface, and for best results make sure it gets good penitration of the hole, even if it means making the hole a little larger.
        aquarium silicone can also be used for a short term fix.TAZ
        nuthing like being woken up at 12:AM to unstop some one elses toilet.
        • dkpbxman
          • Oct 2005
          • 136
          Epoxy putty/Home Depot
          Oatey No. 31270D, 4 Ounce Epoxy Putty - 31270 at The Home Depot
          Comes in two-part tubes. Mix the parts together with gloved hands and apply it. Hardens in minutes.
          Dan
          • 596
            • Jul 2007
            • 90
            Let's get real. If the disposal is old enough for a hole to have corroded through the body, then the grind chamber is likely in similar degraded condition. The likelihood is that you are putting a lot of very coarsely shredded food into the drain line. Clog to follow soon.
            Let's say you have a typical Badger 5 model. It has ( had ) a 2 year warranty, and a reasonable life expectancy of about 5 years. Where are you in that picture?
