Hi all.
I have 2ea, (1997 mf date) 50 gal State gas water heaters located in my garage. They both power a Apollo (aquatherm)heat system as well as the house hot water.
The past 2 nights, in the wee hours of the morning, BOTH heater's TP valves have blown dumping water through out the garage.
Yesterday I chalked it up to a water pressure surge and blew it off. Today, I'm a little more concerned. Here are the particulars:
This time of year I keep the gas on high at the heaters because its still quite cold at night. Anything lesser than 'max' and my gas bill goes way up because the h2o heaters would be cooking all day long. Outside air tems run 60 deg during the day/34 deg at night. The heat system is a split (1 up/1 down) and both zones are on a stat that shuts down the water pump at the air handler when temps are nominal.
Other appliances on the water heaters are: Dish washer, washing machine, and 3 full baths worth of faucets and showers. None of which are running when the TP's let go.
Seems really unusual that both TP's would fail on the same night. It makes me think something else is going one here.
Any direction on this would be appreciated...
Thanks, Randy
Thanks, Randy
