I am hearing at an almost constant rate what sounds to me like water glugging in the sink in our second story bathroom. It is loud enough to wake me in the middle of the night. Nothing is running (no washing machine and no dishwasher). Is it something else running causing this or something backing up? Note: Water tank is in the attic above bathroom.
constant banging from upstairs bathroom drain
Tags: None
Better get up there and check it out...
For some reason I have visions of a pan draining water or a T&P activating on a water heater....I stayed at a Holiday Inn Express last night.
Now I can Plumb!
Just sounds like partial blockage to me have you tried the basic plunger to see if that does anything to the problem. Is the water draining as normal or slowly? i had a what sounds like the same sound you are hearing i just got the gd old plunger out and gave that a good go and was fine for a while but then that sound came back again i kept plunging for a couple of days and its been 2 weeks and its been fine if that doesn’t do the trick get some Mr. muscle
