I am in the process of redoing a bathroom and would like to move the toilet over a couple of inches.. (I am making the bathroom a little larger..) I have a lead bend currently and have read many posts on what to do in order to convert to PVC. However most posts I have read talk about removing the brass ferrule the lead is connected to and use the donut connection etc.. I am wondering however if I clean the brass, can I use a coupler to go directly to the brass?
Connecting to brass ferrule for closet bend
Tags: None
I was thinking there may be a rubber fitting/coupler I could use.. The brass is leaded into the cast iron hub, and then the lead bend is leaded to that brass section. without measuring, i figure there to be about 4-5" sticking out.Comment
The correct way is to remove the brass ferrule clean the inside of the hub out and use a Fernco "Donut" or simmilar product. There are different weights of cast iron used and the hubs are different sizes so you need to get the right size donut.
Fernco Flexible Multi Ring Pipe Gasket, fernco, fernco pipe gasket, Sewer Pipe Flexible Gasket, Multi Ring Sewer Pipe Gasket | Fernco
Now I can Plumb!
