Hello, i have a crack in a pipe on a reducer. The crack is about an inch long and really narrow. can I just solder the crack up, or should I replace the pipe?
cracked pipe
Is this pipe copper ? (you mentioned soldering the crack), from my experience it's very difficult to solder repair a cracked fitting, not to say it cannot be done but it's usually just as easy to remove the effected pipe and fit in new.
Thanks for the reply... It is a copper pipe, and I think I will try to replace it myself.
Now my next question and hopefully someone can help. This pipe goes to my outside waterspout. From what it looks like it goes from a smaller copper pipe to lager pipe that goes outside that is connected to the waterspout.
Is there different pipes i should be concerned about? The bigger pipe looks different than smaller pipe. the smaller pipe looks more copper looking and the bigger pipe looks darker and not like copper. Are these two types of pipe? I have seen type L and type M. can someone explain what type of pipe i should be using?
thank youComment
Is this a frost-proof hose bibb?
If so the hose bibb requires replacement...
Now I can Plumb!
Ok, I have no idea what I am doing with plumbing but looking to do it myself anyways. Looks fun.
so the 1/2 inch pipe needs to go to a 3/4ths pipe and is done by a reducer. That much I got. I was looking in the hardware store and looking to get my stuff when I grabbed a 1/2 pipe and tried to put it on the 1/2 side of the reducer... Well 1/2 wouldn't go on the 1/2 side of the reducer cuz its the same size.
So how do I get the 1/2 pipe in the reducer if its the same size? I'm not a plumber
3/4 copper to 1/2 copper
take a look at my diagram. use EITHER fix --- a piece of 3/4, a reducer coupling 3/4X1/2 inch, or a 3/4 X 1/2 inch bushing. the 1/2 inch copper will fit inside the bushing and it, in turn will fit the 3/4 inch T off the main line.Comment
by eurroexporthello, sorry my english not perfect. my toilet in apartment is making noise ALL THE TIME, like running water sound, even when nobody use it. is this normal...
Channel: Plumbing
