Hello. I noticed a small leak at a pipe joint in my basement. The pipe comes in from the outside well and splits off to the water heater and other sinks/showers /etc in the house. The leak is at a fitting just before the split. Can I just follow the same procedure for sweating a new pipe joint in order to fix the leak, or would I have to separate the pipe and fitting and put on a new fitting, then add the solder?
thanks a lot.
thanks a lot.
