Slow draining glass vessel sinks
  • BMBLBEE
    • Jan 2010
    • 7
    During a recent reno I installed granite counters in all the bathrooms and added glass vessel sinks I bought at Home Depot.
    Unlike regular sinks these do not have an overflow and the drain fittng has a perferated disc to keep things from falling down the drain. When using the sinks water collects in the bowl and is slow to drain unless I swirl the water to release air bubbles just under the surface of the drain disc. It seems like air under the water is restricting the drain flow. Any suggestions for a fix that will let the water drain more quickly?
  • Redwood
    • Feb 2009
    • 512
    Take a drill and make the holes as big as you can without trashing the grid strainer or, rip the drain out and install a lift and turn drain assembly.
    The grid drains are noted for draining just like you describe.
    Now I can Plumb!
    • BMBLBEE
      • Jan 2010
      • 7
      Thanks, changing out the drain assembly was next on my list.
