I just cleaned out all the old mouldy silicone around the base of the shower stall and about 12" up each corner. I really don't want to use white silicone as it turns mouldy and is very noticeable.
I wanted to use black silicone which matches the walls but found that the only black silicone I could find was for windows and doors. I decided to go with clear although I suppose it will end up looking horrible within a few months again.
What I also realized is that when you are down on the floor and working that close to the walls you realize just how bad everything looks. I would love to get some advice on how to keep the shower much cleaner.
I use one of those squeegees to wipe down the walls every week or so which works but never gets the corners very well. I also use those little plastic scouring pads you can get at dollar stores which is not to bad either.
What else can anyone suggest to get the scum and buildup off easier?
