Lost most hot water pressure in tub - sink and other fixtures are fine!?
  • TAHUSKER
    • Feb 2006
    • 22
    Hi everyone . . . hoping someone might be able to help with a plumbing question.
    Last night out upstairs shower/tub lost most of its hot water pressure suddenly. My wife took a shower and was fine, my daughter jumped in shortly after and suddenly the pressure was nearly gone for hot water. The fixture is a Delta, not sure what model. Picture below. It's one of those one-lever deals with a dial on the end that you turn to get hold and/or cold water.
    Like I said, worked fine up until last night. Now, if you turn the knob to what should be the hot water side, there is about 1/4 to 1/3 the volume of water that usually comes out. The sink 3 feet away is fine--full hot water volume. All the other showers/faucets, etc in th house seem to be fine as well.
    Any thoughts or suggestions? Is is possible this got clogged up all of a sudden? We have pretty hard water. Just weird that it happened so fast.
    [IMG][/IMG]
    replace the cartridge on the faucet. the old delta-s used a brass ball and spring loaded rubber seats. this newer type uses neoprene and silicone seats with a turn and rising stem.
    • TAHUSKER
      • Feb 2006
      • 22
      Thank you . . . I will look into that then. Is there a place that shows diagrams of disassembling this kind of faucet?
        In a DELTA site look for an ADDISON TEMP-ASSURE faucet. There are several with a chromed cap not black like yours, but searching the sites may provide one. Look into eBay while you are at it.
