Mixing Galvanized steel and black iron in a gas line
  • JPGarcia
    • May 2010
    I have to make an extension to an interior galvanized gas line. The company does not allow to use any new galvanized steel, but it requires to use epoxi covered black iron. What should I put betwen the two pipe types? Is it Ok to put just a bronze valve? What is the standard procedure? Thank you.
  • paul52446m
    • Nov 2009
    • 690
    If you want a valve there, you can use a brass gas cock. It takes a long time , but over the years the gas will flake off the galvanizing, so that why they don;t
    want you to use it. Any valve you use for gas will say G on the valve. After you get it together and gas in the line check it with soap and water, or you can buy
    some gas leak detector. later paul
    • JPGarcia
      • May 2010
      Thank you Paul, but if I don't want a valve there what should I do?
      • paul52446m
        • Nov 2009
        • 690
        just put a black coupling or nipple on it and go on running your blk pipe. later paul
        • JPGarcia
          • May 2010
          Thanks, Paul. I'd thought doing that, but then I heard about galvanic corrosion. Do you know why is not a problem in this case, or if it is, how to solve it?
          • paul52446m
            • Nov 2009
            • 690
            In water lines you can get electric galvanic corrosion, from the movement of
            water. with gas you don't get enough to worry about. later paul
            • JPGarcia
              • May 2010
              Thank you Paul for your useful help. federico
