Sodering Pipes with Paint on them.
  • mikeylikesit5805
    • Jun 2010
    • 18
    I just bought a home, and found out that there is no water shut offs except for the main. I really want to install some ball valve shut offs but there is paint on all the pipes. What is the best way to get paint of the pipes so that I can solder them? Sand Paper, Burn if off?
    Any help would be great.
  • jayharold
    • Jul 2010
    I would think burn it off and then use steel wool to clean up the pipe. But i am no expert!
      use a flap wheel or a wire brush on a drill.
      • thedcdude
        • Jan 2006
        • 82
        I've always used plumbers emory cloth. Work it back and forth with the same motion you use to shine your shoes. It'll come right off.
        • christopherM
          • Jul 2010
          I deal with this ALOT at work. we paint everything. pipes, bolts, sometimes sightglasses. sandpaper. 220 grit works very well. just make sure you get it all off. don't try and short cut it.
          • Redwood
            • Feb 2009
            • 512
            Plumbers cloth should do fine.
            There are varying degrees of coarseness available.
            Now I can Plumb!
