Whirlpool tub
  • Deanssurplus
    • Jul 2010
    Whirlpool tub
    Hi, I recently purchased an American Standard whirlpool tub that I am also going to use as a shower,it does not have a lip around the top to divert water back into the tub,does anybody have any ideas on how to make a seal around the tub so I can tile around the three sides?
    almost thinking that you'll hafta glue with white or clear silicone, an L shaped pvc angle to the tub top.
    • manhattan42
      • 47
      You can't do it.
      This tub is not designed to be installed to fixed walls and then tiled.
      This tub is meant to be installed as a drop-in type tub unit with clearances to any walls in the alcove.
      Unless your alcove is large enough to provide those clearances from the wall, forget using this one and get a model that is designed for the use.
      Otherwise you will have nothing but trouble with it.
      • Redwood
        • Feb 2009
        • 512
        Yep this will always be a leaking mess until one day when it gets torn out and redone right...
        Now I can Plumb!
        • Deanssurplus
          • Jul 2010
          I found a solution!!
          I came up with a solution if anyone is thinking of doing this: I went to the local steel supplier and bought a piece of 5/8" (solid) square aluminum bar and cut it to go around the perimeter of the tub,i then drilled holes every 6" then I installed a strip of silicone weatherstripping in between the tub and aluminum and bolted it down with 1/4" stainless bolts,i then ran a bead of silicone around the edge.now I will pack the wall out so the wall board will sit on top of the aluminum and I can tile down to the top of the tub. It might sound like alot of work but I got a great deal on the whirlpool tub and I did not have enough room for a separate shower...I will post pics of it when it is complete
          • manhattan42
            • 47
            Yes:
            Post pictures so we can use you as the poster-boy for how to do it wrong!
            • Redwood
              • Feb 2009
              • 512
              Oh Ya pics please...
              Now I can Plumb!
