Newbie with a new leak
  • Tinkerin_wit_tools
    • Jan 2009
    • 46
    Well, long story short, I have noticed my bath faucet dripping excessively the last two days. I have tried looking online, but this forum has so many awesome pros, that I would rather come here. Where should I start looking and how to I start taking everything apart that I need to? As you can tell, I have only worked with the pvc pipes in my basement and they are a snap compared. If anyone has any suggestions or solutions, please don't hesitate to throw them my way. Thanks guys!
    I'll bet the drip is the hot water side. a delta faucet has a single lever with a ball and two spring loaded rubber seats. separate hot and cold valves have replaceable cartridges. 'Cept for real old faucets, packings and stem washers are almost never used.
      • Jan 2009
      • 46
      It actually has two knobs, one for hot, the other for cold. I believe that I read somewhere that this is a certain type of bath faucet. Anyway, from what you say, there are replaceable cartridges??? I will have to wait till the weekend to take them apart and see what the deal is. A buddy at work says you need to shut the water off, drain what is left in the pipes by turning it on, then take the knobs off to see what you can see....
        YES, number 1 thing to do when trying to repair faucets, valves and the like....turn off the water.
        Depending on the faucet it may have wear are tear in the faucet seat, when you take the offending faucet apart look inside where the washer sits and seats down this surface should be free of any cracks and be nice and smooth.
        Speaking of washers, first check the washer when you remove the stem that well could be the offending part and easier than dirt to replace.
        • Redwood
          • Feb 2009
          • 512
          have a good read here...
          Now I can Plumb!
            • Jan 2009
            • 46
            Problem solved! With the help of all of you and a friendly face at the local Home Depot, it is fixed. I took it apart and really didn't see alot of wear and tear, but to be safe, I not only replaced the rubber washer and spring to the rear of the stem, but the stem itself. I am sure that now, there are not only any leaks present, but replacing them will make them last even longer. Cost a few bucks, but the water it must have been costing the past week in all likely-hood was the same if not more from all the dripping. Thanks again guys, and see you next time............
