How Do I Fix a Leaky Faucet?
  • Gardenboy
    • 334
    Hi everyone,
    I have a standard kitchen faucet that’s about 8 inches tall, and it’s started leaking from the spout. The leak seems to be just a slow drip, but it’s getting worse. The handle is about 3 inches long, if that helps. Does anyone have any tips or a step-by-step guide on how to fix this? Should I be replacing the washers or is it something else? Any advice on tools or materials I’ll need would be greatly appreciated!
    Thanks!​
  • TinyTool
    • 357
    Hi there!
    It sounds like you’re dealing with a common kitchen faucet issue. Here’s a step-by-step guide to help you fix the leak:
    1. Turn Off the Water Supply: Locate the shut-off valves under the sink and turn them off. Turn on the faucet to drain any remaining water.
    2. Plug the Drain: Use a sink plug or a rag to block the drain. This will prevent any small parts from falling down the drain while you work.
    3. Remove the Handle: Depending on your faucet model, you may need to remove a decorative cap on the handle to access the screw. Use a screwdriver to remove the screw and lift off the handle.
    4. Disassemble the Faucet: Look for a retaining nut or cap that holds the cartridge or valve in place. Use an adjustable wrench or a basin wrench to carefully remove this nut.
    5. Inspect and Replace Parts: Once you have access to the internal components, check the cartridge or valve for damage. You might also find washers or O-rings that need replacing. These are common culprits for leaks. Bring the old parts to a hardware store to find exact replacements or a repair kit.
    6. Reassemble the Faucet: After replacing any damaged parts, reassemble the faucet by reversing the disassembly steps. Make sure everything is tightened securely but not overly tight.
    7. Turn the Water Back On: Slowly turn the water supply back on and check for leaks. Test the faucet to ensure it operates smoothly.
    Tools and Materials You Might Need:
    - Adjustable wrench or basin wrench
    - Screwdriver set
    - Replacement parts (washers, O-rings, cartridge)
    - Plumber’s tape (for re-sealing threaded connections)
    If the leak persists after replacing the parts, you might need to consult a professional, but this should handle most standard faucet issues. Good luck with your repair!​
