Trim on interior doors
  • wrightwx2
    • Oct 2007
    I am installing 1x4 trim on interior doors and the sheetrock is not flush with the door sills only in areas like the studs are warped leaving gaps at 3/16th's in area and then the rest fits fine. How do I go about fixing this? Any ideas?
  • wrightwx2
    • Oct 2007
    By the way this is new construction!
    • Blackhawk
      • Nov 2005
      • 35
      Since you say that you are using 1x4 trim, it sounds like maybe you have made you own trim. Most purchased door trim will have a wide groove milled along the length of the trim on the back side. This groove helps to absorb any sheet rock edges that are past flush. If you don't have this groove milled in your trim, use a router and mill in at least a 1" wide x 1/8" deep groove that will line up with the sheetrock to jamb joint.
      If you sheetrock is wavy in the vertical, your easiest option is to fill up the gaps with caulk. Of course, this only works with painted trim. For stain grade trim, I see 3 options.
      1) rip down the sheetrock and straighten or replace the crooked studs
      2) live with the gaps
      3) lay the trim against the wall and scribe the contour of the uneven surface to the trim, then use a belt sander to remove material on the back of the trim until the trim matches the wall
      • wrightwx2
        • Oct 2007
        Thanks Blackhawk for the info. I went to the Home Depot and checked it out and will use my router to cut this groove. I have been so busy with all of the other stuff building this house that I needed to just get away from it and take another approach at the problem.
