Problem with the roof
  • DarkKnight
    • 328
    I have a flat roof with an unfinished cement-like surface, and I’m concerned about water pooling on it and potentially getting absorbed over time. I’m looking for a suitable finishing solution that can prevent water from standing on the roof and ensure it remains waterproof. Could anyone recommend materials or methods to properly seal or finish the surface to improve water drainage and prevent absorption? I'd appreciate any advice on long-lasting, effective options!
    Kindly also guide if this project can be completed without professional help. The roof is easily accessible.
  • FatimaandAhmed
    • 343
    For a DIY approach, acrylic roof coating is probably your best bet. It's relatively user-friendly and provides good protection against water absorption. Think of it like painting your roof with a waterproof shield. You'll need to thoroughly clean the surface first, repair any visible cracks with cement filler, and then apply the coating evenly. Most acrylic coatings come in white or light colors, which is actually great because they reflect sunlight and help keep your home cooler.
    However, I should mention that while this can be a DIY project if you're handy and comfortable working on roofs, there are some important safety considerations. Make sure you have stable footing, work during dry weather, and have someone around just in case. Also, look out for signs that might indicate you need professional help instead – things like multiple cracks, significant water damage, or if you're just not confident about handling it yourself.
    If you decide to go the professional route, they might recommend more robust solutions like polyurethane or bituminous membranes. These are more durable and long-lasting, though they'll cost more upfront. A professional can also ensure proper drainage slopes are maintained, which is crucial for preventing future water pooling.
    • DarkKnight
      • 328
      Thank you! Since I haven’t worked with roof coatings before, could you share some tips on how to get a smooth, even layer? Should I be using a roller, brush, or maybe another tool to make it look good?
      • FatimaandAhmed
        • 343
        Sure DK, no problem. Start by making sure the roof is thoroughly cleaned and dry. Any dirt, debris, or loose material can prevent the coating from adhering well and may create uneven spots. If you spot any mold or mildew, clean it off with a mild bleach solution before beginning.
        For the application itself, a long-handled roller with a ¾ to 1 ¼ inch nap is a great choice for spreading an even layer over larger, flat sections of the roof. This method is generally quicker and helps achieve a consistent coat. A large brush, however, is handy for working along edges, seams, or spots that need extra sealing, and it’s helpful for getting into those tricky areas a roller might miss. If your roof is flat or has a gentle slope, you might even consider starting with a squeegee to spread the coating initially, then following up with the roller for a smooth finish.
        As you work, try to keep even pressure on the roller to avoid creating streaks or thin spots, and overlap each pass a little to ensure there are no gaps. Also, be sure to apply the coating in dry, moderate weather—ideally between 50 and 90°F—since very humid conditions or intense sun can affect the drying process and how smoothly you’re able to spread the coating. Finally, check the instructions on your particular roof coating product; some need more than one layer with a specific drying time between coats. Working in sections from one side to the other will help you stay organized and maintain an even layer across the roof.​
        Let me know if you need any further help, thanks!
        • DarkKnight
          • 328
          Thank you for explaining in detail. One more thing, how do I ensure water flows toward the drainage points? Are there thickness adjustments I should consider?
          • FatimaandAhmed
            • 343
            You're welcome. To help direct the water flow towards the drainage points, there are a few things you'll want to consider:
            Slope Adjustments: Ideally, your flat roof should have a slight slope (typically between 1-2%) to allow water to naturally flow off the surface. If your current roof is completely flat, you may need to make some slope adjustments. This could involve adding a thin layer of sloped concrete or using a self-leveling compound to create a gentle pitch towards the drainage areas.
            Thickness Variations: In addition to the overall slope, you may also want to look at varying the thickness of your waterproofing material. Apply it slightly thicker around the perimeter and high points, then taper it down towards the drains. This helps ensure water doesn't pool up in the middle or at the edges.
            Drain Placements: Make sure you have properly placed and functioning roof drains. Ideally, they should be located at the lowest points on the roof to efficiently collect and remove standing water. Check that existing drains are clear of debris and that the drainage pipes underneath are in good condition.
            Combining Slope, Thickness, and Drain Placement: Work with your materials or a professional to coordinate all these elements. The goal is to create a cohesive system that smoothly directs water off the roof without creating any low spots or problem areas.
            Let me know if you have any other questions - I'm happy to provide more details on the techniques and strategies to ensure effective water runoff.
