Adhesive stencils for larger wall murals
  • Adhesive stencils for larger wall murals
    Hello everyone! Adhesive stencils for larger wall murals? How well do they stick to surfaces like brick or stucco, and are there any tricks to prevent peeling during painting?
    Hi!
    Generally, adhesive stencils don't stick as well to rough surfaces like brick or stucco compared to smooth walls. The unevenness can prevent full contact, leading to gaps where paint can seep under. However, there are some strategies you can use:
    1. Choose the right stencil: Look for stencils with a strong adhesive backing specifically designed for textured surfaces.
    2. Clean the surface thoroughly: Remove any dust, debris, or loose material that could interfere with adhesion.
    3. Use spray adhesive: Apply a light coat of repositionable spray adhesive to the back of the stencil for extra hold.
    4. Press firmly: Use a stencil brush or roller to press the stencil into all the nooks and crannies of the textured surface.
    5. Work in smaller sections: For large murals, it might be better to use smaller stencils or work in sections to ensure better adhesion.
    To prevent peeling during painting:
    1. Use a dry brush technique: Instead of fully loading your brush with paint, use a nearly dry brush and build up color gradually. This reduces the chance of paint seeping under the stencil.
    2. Dab, don't brush: Use a dabbing motion rather than brushing strokes, which can lift the edges of the stencil.
    3. Consider stencil adhesive: Products like stencil adhesive sprays can create a tighter seal between the stencil and the surface.
    4. Remove the stencil carefully: Peel it off slowly at an angle, rather than lifting straight up.
    5. Touch up as needed: Have a small brush ready to clean up any bleeds immediately.
    Remember, working on textured surfaces like brick or stucco will likely require more patience and touch-ups compared to smooth walls. It might be worth doing a small test area first to get a feel for how the stencils work on your specific surface.​
      Thank you!
