Wallpaper come down
  • zhshqzyc
    • Jun 2011
    • 6
    Wallpaper come down
    Hi, the wallpaper come down. For the curly edges, it is very hard to fix them. I bought the glue(see image attached) from Lowes, it works well for the wallpaper central area. However it doesn't work well for the edges.
    The images are attached.
    Thanks for help.
    use the type glue used for heavy wall coverings like an oilcloth based paper. dampen the paper so it won't curl back up, apply the glue and press it in place. when the wallpaper sheet went up, the whole sheet was wet with glue.
    • harshi
      • Jun 2011
      Wallpaper come down
      Yeah! use good quality glue and press properly.
      I'm sure you will not get such problem in future.
      Good luck!
      • monicat
        Banned
        • Nov 2011
        Had the same problem at some point. By the time I found some good glue to fix it, it was too late cause the wallpaper was already ripped in one corner.
