I am looking at a house which has an odd fireplace/chimney construction. A brick fireplace is installed in the basement. A brick chimney goes through the first floor up to the roof. There is no fireplace on the first floor. Instead, the brick chimney wall is covered with a drywall (doesn't it get hot?) on the first floor. It makes the room look wierd.
Is it possible to take down the drywall covering the chimney wall, make a hole in the chimney and make a fireplace on the first floor?
I've seen houses which have fireplaces right on top of each other sharing the same chimney.
Thanks in advance.
Thanks in advance.
