I am finishing my basement.
I built some walls last year and I am now getting back to the task. Problem is many of the vertical boards are warped now either in or out. I don't think replacing all (many) of these boards are the answer. Won't they just warp again? I did not force the wall into place so the floor above expanding did not force down on the framing.
My plan was to notch across the wall and screw in some horizontal boards to pull the bad ones back in place. Will this work?
Also, I have poured walls that I believe were done by a crew of drunks. Putting framed walls against this surface and keeping them plum is a real pain. I pull the top or bottom out until they are plum. One eight foot section of wall I may get right, but the next butting eight foot section may be the exact opposite. Keeping these two sections in line is next to impossible. My question is how important is it really to get these walls perfectly vertically level? Obviously perfect is best, but if I keep the "bubble" inside the ticks but not perfect, will it be real noticeable once the walls are sheetrocked? That really sounds stupid but any help would be greatly appreciated.
