Hi all,
I'm a first time apartment renter and I'm trying my hands at what should be something quite simple: installing drapery tracks.
My problem is that I need multiple pieces of track to stretch the length of the window. Because my window reaches right to the ceiling, my only option for supporting the tracks in the middle is screwing the little clamps into the cieling... This task has become the bane of my existance!
The apartment that I'm in is about 40 years old. The cieling is made of plaster (approx 1" deep before I hit whatever solid frame is behind it). Everytime I try to screw into the cieling, the screw won't grab the plaster. It just ends up making a hole and the screw pulls right out. I have had similar problems with my plaster walls, which I solved by using drywall plugs. Even those don't seem to work in this cieling. Again they just make holes, it doesn't seem like anything can bite into the plaster and stay there. My ceiling just chips and falls apart with each new screw or plug I try to put in it... Does anyone know what type of fastener I can use in my cieling to support my drapes? ... Am I a lost cause?
Any info would be super, because I'm consider putting tinfoil over my window!!!
Thanks,
Aaron
Thanks,
Aaron
