Replacing Stucco/Plaster Walls
  • m0nty005
    • Oct 2008
    I have a 2400 sq ft contemporary w/ high ceilings & skylights where all the interior walls are stucco/plaster. My question is how much would it cost to turn it into plain flat drywall.
    Thanks!!
    • 8747
    stucco and plaster is affixed to the wall/ceiling surface using a metal lath screen which is in turn fastened to the studs. you'll need to locate all the studs to fasten the sheetrock to. I don't know for fact that the sheetrock screws will even penetrate the stucco which is concrete. bascially I'm thinking to knock down all the stucco and start anew. it will be expensive to say the least and very messy.
    • tom_matthews
      • Aug 2005
      • 55
      try this article
      they covered plaster with drywall here:
      Giving Walls a Drywall Update | Extreme How To, DIY - Do it Yourself, Home Improvement, Home Decorating
      • give813
        • Jan 2009
        a cheaper option would be to put a few coats of joint compound over the stucco.
