Drywall tape bubbling?
  • dblazier
    • Jan 2009
    If anyone can shine some light on this i would be very grateful.
    I have a wall where the drywall tape has started to bubble. Along the entire seam there is a problem but very noticable in one spot. It is an interior wall although it is about where the two different pitched roof lines meet.
    I have also seen some odd streaking (blistering as well but in the shape of a streak) running down the walls.
    Has ANYONE ever had this happen?
    Thanks
    Dave
  • jnaas2
    • Feb 2008
    • 213
    Drywall tape will bubble like that if it gets wet from a roof leak , water leak, if it was installed improperly, or if the walls are moving . Going by the streak you are talking about and that this is in a area where two roofs come together,I would say you have a roof leak
