I want to redo my shower and I found a slate at a home improvement store that I like? Do you recommend slate in a shower and do you have to seal it?
Placing slate in a shower
Tags: None
Personally, I don't recommend slate in a shower. I just finished rebuilding a shower for a relative. It had been done twice before in slate, and never was right.
I think the biggest problem can be with the sealer. That's one thing you don't want to try to save money on. I talked with a local tile dealer and his recommendation was that it be sealed several times after the initial installation, and every year or two after that.
There are several ceramics available that look similar to slate. They are also much cheaper, easier to install, and don't require sealing. Here's one I did a few years ago:
I think slate is a great idea for a bathroom shower wall. It's very trendy nowadays and is extremely durable and long-lasting- even more than ceramic tile. It should be sealed for added protection. Double check that the slate is water proof as some slate is not.
_______
Networx.comComment
by AshRaeI have a hole in my wall about the size of a doorknob (oops) — is there an easy way to fix this myself or do I need to hire someone? First time dealing...
Channel: Walls and Wall Coverings
by eurroexportI want to hang shelf on wall but wall sounds hollow when I knock on it, not like the brick walls back home. how I hang something heavy on wall like this...
08-21-2026, 03:47 PM -
by BodreyI'm renovating my house right now including installing new drywall. Just today, I started taping the living room, but now I'm seeing that some of the...
